CEL Codes, what's wrong
Old Mar 9, 2006 | 11:42 AM
uinthas's Avatar
Trying to get a work truck back & running, it's a 99 F-250 with a 5.4.. These are the codes it's giving 1131, 1254, 171, 174.. Doesn't have much power on the freeway, if you get into the gas or RPM's to far it just doesn't react & bogs down. I know these are lean codes, is it most likely a problem with cloged ports & such??
Old Mar 9, 2006 | 04:24 PM
projectSHO89's Avatar
P1254 appears to be an invalid code. Please recheck.
P0171 & P0174 together are usually a vacuum leak, usually the PCV hose elbow. SEARCH keyword "P0171 P0174".
P1131 is a weak upstream O2 sensor on driver's side. Since yuo also have the codes related to vacuum leaks, fix those first as a vacuum leak can skew the accuracy of the O2 sensor tests.
Steve
Old Mar 9, 2006 | 06:40 PM
uinthas's Avatar
Sorry, 1254 is really 1151
Old Mar 10, 2006 | 07:33 AM
P1151 (driver's side) is the complementary code to P1131 (Passenger side - please correct previous notation).
Follow my advice given above as is still applies.
Steve
Old Mar 10, 2006 | 10:40 AM
uinthas's Avatar
Thanks for your help, I'll check it out once it warms up a little more around here...
