Help ! 1997 Ford F150 4x4 4.6 V8 LOok!
I have a mis fires in almost every cyclinder but not at the same time. I have a excessive flow in the egr and my truck just started clicking in the engine i dont know wtf to do anymore. check out what i have Already done...
Replaced egr,dpfe,coils,spark plugs,fuel regulator,fuel filter,iac,air filter....
Cleaned the fuel injection,spark plugs , plug wires, air intake, egr intake, throttle body, hoses....
Still the same problem. good idle, bad shaking and misfiring when i hit the gas....
can anyone help pleas......
How do you know its misfiring in every cylinder?
Also, how will cleaning the plug wires help any, I suppose to mean you cleaned the contacts? I would go ahead and replace the wires since nothing else has helped.
My 4.9 was doing somthing simular I found a problem with the seal between the throttle body and manifold... start looking for a vacume leak.. could be the issue..
Is the timing good?
My issues are 100% solved yet but that leak on the TB was a major part of them.
Jason
Is the timing good?
Jason
