5.4 3v useing oil?
Old Jan 22, 2006 | 02:56 PM
cyclone vampire's Avatar
5.4 3v useing oil?
every 5000 km I change my engine oil, truck has 45,000 km on it, 2000 km shy of next oil change, verry seldom do I check my engine oil, I checked it today, and I'm down 1 Lt..verry odd...
Old Jan 27, 2006 | 06:36 PM
chester8420's Avatar
my 97' always uses oil. I don't know why.
Old Jan 28, 2006 | 07:02 PM
98Navi's Avatar
Well, since most of us here are on the mile schedule, 5000km is 3105 miles. Its not abnormal to burn that much. I usually burn through 2 quarts in 3000 miles. Ford considers this normal. Check it more frequently, and continue with your 5000KM service interval and you shouldn't have any issues
Old Jan 29, 2006 | 10:31 AM
Podunk's Avatar
2 quarts between oil changes isnt normal.
His truck is new????
My 2004 has NEVER needed oil between changes.
I dont even think it burns half a quart between oil changes.
Old Jan 29, 2006 | 10:57 AM
98Navi's Avatar
According to Fords specs, anything less than 1 quart per 900 miles is normal.
Old Jan 29, 2006 | 12:59 PM
I'm checking my oil every 2nd day, So far oil level is at correct level after I added a Lt ...due to be changed soon. Possibly the Ford Tech's did not add the correct amount at my last oil change, or the truck is using oil. to soon to tell.....at a drive threw my truck is louder than a power stroke, The sound of ticking, tappet, injectors, is bounced off the side of a drive threw is louder than a power stroke, at idle, my 04 5.4 is louder than my dad's 06 6.0
Old Jan 30, 2006 | 09:11 AM
GIJoeCam's Avatar
Ditto. The official Ford spec is 1 quart in 900 miles is considered "normal". They won't do anything about oil consumption if it's anything less than that.
-Joe
