BAP Sensor
Old Jan 21, 2006 | 09:04 AM
Fanuc's Avatar
BAP Sensor
Can any one tell me where the BAP sensor is located on a 2003 5.4
Old Jan 21, 2006 | 09:56 AM
projectSHO89's Avatar
Don't think Ford used a BAP on the '03 5.4.
It isn't on the earlier 5.4s up to '02.
What leads you to this question?
Steve
Old Jan 21, 2006 | 10:13 AM
Fanuc's Avatar
slight ping when the outside temp drops below 40 or when the temp goes up from 75 to 100 .. after 100 it stops .... this doesn't happen all the time
Old Jan 21, 2006 | 01:52 PM
Bluegrass's Avatar
BAP = barometric air pressure. Not used since the last 5L engine.
Your discribing an operation where the low temps adds fuel and the hi temp pull ignition timing, that stops the ping.
If truly a sleight ping, it is gas related IMO.
These engines live right on the edge all the time.
A difference in tolerences of tuning, parts and fuel often add up to an over the edge operation if one element is to far out side..
The engine senses the inlet temp from the IAT in the air tube with the air meter.
Could even be the air meter dirty etc.
Good luck.
Old Jan 21, 2006 | 02:16 PM
Fanuc's Avatar
I have tried all brands of fuel and that makes no change ... my wife says it sounds like an exhuest leak to her .. but I have checked that too .. the stealership could never find the problem either
Old Jan 22, 2006 | 10:45 AM
Have you tried a different wife?
Old Jan 22, 2006 | 11:09 AM
PONY_DRIVER's Avatar
Old Jan 22, 2006 | 11:17 AM
Fanuc's Avatar
yea but 2nd one is the same as the first
