Plug blow out advice $$$$$$$$$$$
Old Jan 13, 2006 | 12:39 PM
dswhalen's Avatar
I called Time Serts and their kit is $350.00 ouch! Is a heliocoil cheaper?
Are there any threads on doing a heliocoil vs an insert?
Old Jan 13, 2006 | 12:50 PM
MGDfan's Avatar
OUCH is defined as $,3000 + for a new head.
Consider the kit as a reasonably priced alternatve that does not require head removal in most cases, and I beleive it comes with enough inserts to do more than one plug. Conventional wisdom suggests you should remediate them all while your'e at it.
Timeserts are superior to heli's - there's a ton of posts on that as well. Don't choose the cheapest route.
As I indicated before - use the Search function!
And, do the PM on your new 3V's !!!
Good luck
Cheers
Grog
Old Jan 14, 2006 | 12:22 AM
LilBlackCoupe's Avatar
What does the dealership charge to do one??
Old Jan 15, 2006 | 10:31 AM
Johngs's Avatar
dealerships wont usually do inserts, they want to replace the entire head. Youd be looking at at least $2000 for that.
