Help Me!! Need Code P1154 explanation!!!!
Old Jan 9, 2006 | 09:13 PM
topsybunch's Avatar
Question Help Me!! Need Code P1154 explanation!!!!
Have 97F150 with a P1154 code. Bank 2 Fuel control shifted rich as explanation. Need to know where controller is and what it is.
Thanks bunch
Old Jan 9, 2006 | 09:14 PM
lees99f150's Avatar
what engine?
Old Jan 9, 2006 | 09:17 PM
topsybunch's Avatar
engine is a 5.4
Old Jan 9, 2006 | 10:17 PM
Quintin's Avatar
P1154 isn't a valid code, I think you mean P1152. Bank 2 is trying to correct for an overly rich condition, you'll probably have long term fuel trims on that bank trying to take out a lot of fuel, like 10-12% if not more. I won't tell you to throw an O2 sensor on it just yet, but inspect your wiring at the upstream O2 sensor on bank 2 (driver's side), make sure it isn't chafed or frayed against anything, or that the wiring isn't tangled up as if someone tried to remove the sensor without disconnecting the connector first. Of course, check the basics, no unmetered air leaks after the mass air flow sensor, EGR's working properly, PCV system is working properly (check the PCV tube where it runs around from the passenger's side valve cover and connects to the rear of the throttle body), no sticking or leaking injectors and such. If visually everything looks okay, you may need an O2 sensor.
Old Jan 14, 2006 | 08:00 PM
topsybunch's Avatar
found problem, thanks for help
found the pvc line where the connecting boot connected to the back side of intake had a hole ih it. (symtons rough idle, check engine light,test showed lean on o2 sensors, rich on bank 2, plugs not sooted, clean exhaust burn.)
