Underdrive pulleys
Old Jan 8, 2006 | 12:26 PM
mhs's Avatar
mhs
Underdrive pulleys
I have the opportunity to purchase underdrive pulleys that came off a 98 cobra for $35. I'm wondering if they will fit on my '97 4.6 F150. Also, is this actually worth doing? The only other change I've made is adding a K&N type intake.
Old Jan 8, 2006 | 12:50 PM
ONELOWF's Avatar
I'm not sure about the fit, but ud pulleys are'nt worth much in terms of seat of the pants performance gains.
Also, a two pulley set up will underdrive your alternator, which is usually ok, but didn't work well for me.
IMHO- save yer $. LOL
Old Jan 8, 2006 | 03:49 PM
98Navi's Avatar
I woulnd't waste the money. I had underdrives on my 5.0, and took them off. They caused the engine to run hot, and the alternator to "underproduce" even with a higher amperage unit. I did leave the crank uinderdrive pulley on, but the rest came off. Save it for something else
Old Jan 8, 2006 | 05:58 PM
mhs's Avatar
mhs
Thanks for the replies. I appreciate all the advice I've gotten here, either directly or indirectly.
Old Jan 8, 2006 | 09:50 PM
98Navi's Avatar
But I will add this. You live and you learn. What caused me and 20 other fellows issues may not cause you a single solitary problem. I would say get only the crank pulley and sell the others for best performance gains without losses in other dept's.
Old Jan 9, 2006 | 04:11 AM
Sparky604's Avatar
i've heard of many people putting on underdrive pullies and loving them. some say it's the best money they've ever spent. i bought a set myself a while back but changed my mind and decided to trade them on a set of 4.56 gears. for about $150 they seem like they might be a worth while mod to me. i heard of one person having charging problems from the small alternator pulley but that could have also been attributed to a bad alternator or battery too. i've also heard of a guy with a 5.4 with efans and the full set of pullies and no charging or cooling problems at all.
Old Jan 9, 2006 | 06:44 PM
Faster150's Avatar
most but not all of the trucks use an 8 rib belt the cars all use 6 rib belts.. u could convert all of the pulleys on ur engine to accomodate but its best just to buy the ones for the F150. also the cobra uses a different water pump...
Old Jan 9, 2006 | 10:58 PM
KickinBlue4x4's Avatar
You can buy either 6 or 8 rib pullies from troyer. That is what I run, a small noticeable gain. Not worth the $150 or whatever they are new, I got mine used from the classifieds on here for like $75. Not too hard to install either.
