Radiator problems
Old Dec 11, 2005 | 10:09 PM
peskador's Avatar
Radiator problems
Thanks for everyones input ,this site is awesome,My question is this I own a 1997 F-150 4x4 3rd door 5.4 engine,this will be the 4th radiator in a year and 6 months ,the r/s, passenger side, radiator tank seam leaks, Why? I donot know, But is it posssible abody mount is loose or worn to when my truck goes through uneven driveways roads,speed bumps is causing the seam to twist and start leaking? Anyone encounter this problem ? or heard of something similar? Any ideas what will help me figure this out ? Thanks in adcance Pesk
Old Dec 11, 2005 | 10:17 PM
Yankee7985's Avatar
SOunds like crappy replacement radiators. Remember, the radiator is basically held in by (4) rubber isolators. This is what helps dampen the vibration. I would try a different brand of replacement.
Old Dec 12, 2005 | 12:20 AM
Johngs's Avatar
Wait is it the radiator that is leaking, or the overflow tank?
Old Dec 12, 2005 | 12:24 AM
JMC's Avatar
JMC
25 Year Member
Have it pressure tested at operating temp. A blown head gasket will let combustion chamber gasses into the coolant system. There are also products that you can buy to test. There is a dye that you put in the coolant over flow tank to check.
JMC
Old Dec 12, 2005 | 08:34 AM
spray004's Avatar
JMC
Yup a busted head gasket or failing head bolts can cause combustion gases to get into the cooling system and ruin even a good radiator.
