2004 Ford Speedo Question
Old Nov 28, 2005 | 11:57 AM
rjmlakota's Avatar
Registered User
I'm new to this site so I'm not sure if this post in the correct location.
I just purchased a used 2004 F150 FX4 w/ 18" tires. Well, I hooked my GPS up and wanted to see if the speedometer was accurate. According to the GPS when the speedometer is at 60 the GPS says 56? I have used the GPS to check speeds before and it has always been correct. I am thinking it's an issue with the speedometer? Has anyone else ever seen this?
Thank you – Ray
Old Nov 28, 2005 | 06:33 PM
Quintin's Avatar
4-5 mph difference isn't unusual, I wouldn't lose any sleep over it. I'd be more interested in what the VSS actually said as opposed to the speedometer.
Old Nov 29, 2005 | 10:19 PM
electec's Avatar
Thank you – Ray
I have a 2004 F150 Lariat w/ 18" Wheels.
With my truck at 60 on Cruise Control my Garmin shows 56 MPH.
The GPS is right-on in my other trucks (or my speedo is off..hmmmm)
I am taking mine to the dealer for other issues and was going to have them check it out.
Qiuntin,
I am an idiot, but what is a VSS??
Old Nov 29, 2005 | 10:38 PM
Quintin's Avatar
Vehicle Speed Sensor. I'm more interested in what the VSS says since it'll show a true representation of speed, as opposed to the relatively rough guestimate that the speedometer offers.
Old Nov 30, 2005 | 12:54 AM
rawzon's Avatar
funny, i was using my gps while driving a couple months ago and i was going 75 gps said 71.. i think its safe to say stock are over by about 4 mph
Old Nov 30, 2005 | 01:19 AM
Podunk's Avatar
When you wear the tread down on a pair of tires, the speed is going to change a bit.
I know that sounds stupid, but tire tread can change the speedo by 2-3 mph.
Besides, most speedometers are off a mile or 2 any ways.
If you want a 100% accurate indicator of speed, then you probably shouldnt use your speedometer.
Old Nov 30, 2005 | 08:09 AM
mobandit's Avatar
Speddo is off, Odometer is probably close to dead on. There is a 1-5% standard error allowed in the US auto industry on speedos. My Japanese motorcycle is off by nearly 10%...that's why when I go to larger tires I may not readjust the computer for those larger tires. The 265/70/17's I want will just about offset the current error.
Old Nov 30, 2005 | 09:58 AM
Podunk's Avatar
I thought they used the same sensor???
Old Nov 30, 2005 | 04:07 PM
mobandit's Avatar
They most likely do, but how that signal is used and displayed is easily manipulated electronically. For instance, the Speedo and Odo on my bike are mechanical, driven off a cable from the front tire. When I am running an indicated 60 MPH my GPS tells me I am only doing about 54-55 MPH. But my Odo and the GPS are clicking off the miles nearly exactly together. In this case, the faceplate of the speedo is off by about 5-10 percent. The gearing is correct to indicate MPH and distance, but the faceplate is deliberately off. The same can be done with an electronic speedo and odometer.
Old Dec 7, 2005 | 01:01 PM
Ice King's Avatar
Ray,
I just drove my new F150 FX4 with 18" tires off the used car lot last evening. On the way home, I set the Cruise at 60 and my wife (following) said why and I driving 56?
I will use my GPS to confirm the inaccuracy of the Speedometer.
Matt
