MPG. Tailgate up or down?
The quote I quoted wasmis-quoted from above.... the computer saw the errant " [ / quote] and ended it there. I corrected it in my post now.... I was referencing the second part of your post.... sorry for the confusion.
-Joe
-Joe
30 gallon tank
Hey, I think faster F 150 said he had never heard of a 30 gallon tank in a F150, guess what....I have a 97 F150 4x4 ext cab 4.6 5 speed, 8 foot box, 3.55 rear gears bone stock with a 30 gallon tank. I think the early F150's ext cab with 8 foot boxes came with a 30 gallon tank, maybe more I don't know...That's alot of gas!!!!!
Originally Posted by TruBluSuperCrew
A lot of the newer trucks have 30 gallon tanks and some with 37. I have tried the tailgate theory myself, and found out I do better with the tailgate up by about 2-3 gallons.
Originally Posted by GABoyinTroupCo.
I'm sure you are about to get some people saying that little bit of difference could be attributed to driving style and/or gas. But I'm not going to argue one way or the other because I think having your tailgate up is the way to go. Plus why would Ford put them there if it caused your fuel mileage to go down? Wouldn't they just put rails on them? They sure would save some money on fabrication and paint costs. Anyway, when it comes down to it riding around with your tailgate down makes you look like some idiot that buys into conspiracy theory's and garbage like that.
Just for the record, mine is up even with the tonneau cover off....
On a side note... remember the last wind tunnel they built? They were testing the whole bullet-hole through the plane window pressure difference.... (i.e. would the air blowing over the window generate a pressure differential).... was I the only person yelling at the screen that A) the window was oriented the wrong way with respect to the airflow, and B) The pressure differential varies with the square of the speed of the air, so the difference at 60 mph was not linear when extrapolated up to 300-500 that a plane flies at?!!? It seems like you should need to have at least TAKEN and PASSED an entry-level physics course to be on that show.... I always end up yelling at them at some point in the show..... do ANY of them even understand that you need to apply the force to the center of gravity to prevent the dummy from spinning out of control???? No concept of simple physics a lot of time....
[/rant off]
-Joe
Originally Posted by Faster150
and ive never heard of a F150 with a 30 gallon tank... the largest i know of is a 23 gallon unless were talking old school twin tank setups.
My brother has a 2000 F-150, 4x4, regular cab, long bed, and it has a 30+gal. fuel tank.
I thought you knew everything about ford trucks? I guess not....
Well a lot of people are very short sighted. They don't have long and varied experiences and take uninformed positions and use no common sense let alone any technical sense.
These boards are open to the whole world so what you see is what you get.
It varies from such questions as "how can I cancel the CEL lamp and not fix anything" to people who spend tens of thousands on modified engines.
I have to wonder were these people are coming from in relation to the average.
One has no common sense, the other has more money to spend than brains.
Then again lots of post I don't even bother with.
Every board is like this.
When I was younger and dumber, and still knew everything, I had no doubt that the tailgate created a drag effect. Besides, the thing weighed quite a bit, so removing it seemed like the only logical thing to do. I installed a net, and left my tailgate in the garage for a couple years. Once the net finally rotted through, I put the tailgate back on, and to my surprise, noticed better gas mileage. I didn't check to see exactly what the improvement was, but it was enough that I could tell by how long I could go between fill-ups.
In my truck, the way I drive it, and where I drive it, I get noticeably better gas mileage with the tailgate up. But that's just me.
I'm sure that this in conjunction with a turbonator will improve MPG!
