Replacement Radiator
Old Nov 20, 2005 | 11:25 AM
Bronco's Avatar
Question Replacement Radiator
Radiator sprung a leak a couple of days ago. I have been looking for a replacement at the local auto parts. All they can get is OE type replacement. If I have to pull this thing and put in a new one, I do not want a radiator with plastic sides.
Has anyone replaced thier radiator with an all metal one? If so, where from and how much? Also, was it just a drop in, or did you have to modify?
Any Help would be great. Thanks
Old Nov 20, 2005 | 03:51 PM
Bluegrass's Avatar
I don't think your going to find an all metal replacement unless iti s custom built.
I replaced with a two row unit for higher cooling capacity and found upon research that most of the replacements are made in Canada with a universal system of construction that can meet nearly all OEM fit requirements.
I have an OEM original in perfect condition except for the trans cooler fittings I had to use for the new unit install.
Old Nov 24, 2005 | 01:16 AM
PauX3's Avatar
i'm not sure if you can find an all metal as for your replacement. my friend got these radiator, he had no problems with it.
Old Nov 24, 2005 | 02:31 AM
cafasco's Avatar
Very tough, but try Summit Racing. Shop around in town and on-line for an OE style rad that comes with a life time warranty. They should last 100K in the harshest enviroment. When you reach that point and it fails, go get a free one.
Old Nov 26, 2005 | 04:02 PM
Bronco's Avatar
Thumbs up
Couldn't find a all metal radiator, so I went with a Modine radiator from radiator.com. It has a lifetime warranty, so i'll never have to buy another one. Thanks for all your help guys!
Old Jan 27, 2006 | 06:27 PM
vader716's Avatar
Hey Bronco,
how has the radiator held up from radiator.com? I'm thinking of getting one for my mustang....seems too cheap to be good.
