Bad engine miss,OD light flashing
98 expo, 4.6l 4x4 O/D light
Ok, so I have a same, the issue @ hand is this. No problems with shifting, generally it's cold here in Central Oregon so Temps get to single digits @ times. No codes, 1 pending mass evap leak, but check engine light isn't on. Doesn't hesitate one bit, so im at a complete loss on what the actual issue could be. Could it be the stupid torque converter? I'm looking @ diff Trans from jegs as there's some cool kits out there for this rig, but the converters are pretty expensive, like $600+
Hi there, I do have an obd2 scanner, the evap code pending is p0455 mass evap, not sure on the transmission, theres been snow on the ground so havent climbed under there to see the tag
Look at the door jamb sticker, TRANS code E is E4OD, U is 4R70W.
A code p0455 most likely means one or more of the following has happened:
A loose or improperly affixed gas cap
A non-conforming gas cap (i.e. not factory/original brand)
Other leak or damaged piece in EVAP system
Possible Solutions
With a p0455, the most common repair is to:
Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
Otherwise, replace the gas cap, and/or Inspect the EVAP system for cuts/holes in tubes/hoses (you may hear a vacuum noise or smell fuel), repair if necessary
Read more at: https://www.obd-codes.com/p0455
Copyright OBD-Codes.com
Not all OBD2 scanners can read Ford transmission codes. Generally, you have to spend close to 100 bucks unless you get a ELM327 adapter and use a laptop with Forscan or a phone with Torque Pro.
Possible Solutions
Possible Solutions
Possible Solutions
