'97 Oil Pan removal
Old Nov 10, 2005 | 08:25 AM
Darinmm's Avatar
I don't believe this is from the head gasket. The only oil is on the underside of the motor. My other thought is that it would be the front seal.
Old Oct 13, 2024 | 03:50 AM
Gina G's Avatar
Originally Posted by Darinmm
I have a 97 4.6, V8, 4x4 Supercab and need to remove the oil pan to replace the gasket. At least I believe this is where the leak is coming from. What do I need to do to remove the oil pan? Sounds like lifting the engine, however some help would be appreciated.
Where are the four bolts located that attach it to the frame
Old Oct 18, 2024 | 02:05 AM
Veteran: Army
the oil pan IS NOT attached to the frame…
