replacing fuel filters
im quite a newbie to being a mechanic, but I have a 02 Screw and Ive beeen reading that accelaration is affected by fule filters, I havnt had replaced in about 20k miles, how is that one goes by and replacing the fuel filter, also my truck idels at about 700rpm, is that normal...?
I belive you just need a screw driver, I dont' remember, the filter should cost less then 15 dlls at any Ford Dealer or AutoZone, just check under your truck you'll know right away what tools you need.
That above link will tell you what you need to know about removing the filter.
You cant remove it with just a screwdriver, you have to have a fuel filter disconnect tool (shown in the link).
If you buy the filter from Ford, its between $15 and $20. If you buy one from AutoZone or Advanced Auto or whatever, its usually less than $10.
I hear all kinds of differing opinions on when to change it, so I just do it about once a year-ish...its cheap enough that its not a huge deal or anything if you do it "too often"
I ran my 97 with the oem filter for 120,000 miles never had a problem and when i cut it open it still may have had another 20,000 on it.
It really was not very discolored nor was it plugged in any way.
