Confused! Is the 5.4l 3V a small block or big block?
Old Oct 23, 2005 | 01:32 PM
exx's Avatar
exx
Its a small block, i dont even know why its being debated.
Old Oct 23, 2005 | 02:14 PM
Tun2One's Avatar
The main reason I'm asking is because I have a blown motor and the service guy said they will replace the "small block". I remember back when (20 years?) somebody I knew had a chevy big block that went bad and the dealership replaced it with a small block. I just want to be sure that I get the same size of engine and not some smalller v8 - if that's even possible.
Old Oct 23, 2005 | 03:36 PM
momalle1's Avatar
Are you sure he didn't say "short" block?
Old Oct 23, 2005 | 04:09 PM
wstahlm80's Avatar
Originally Posted by JerseyGeorge
It's a "BIG" small block!
I thought it was a small big block....
Old Oct 23, 2005 | 04:51 PM
exx's Avatar
exx
Pffffffff, its more like a small small block.
Old Oct 23, 2005 | 06:58 PM
adrianspeeder's Avatar
Originally Posted by momalle1
Dang, you are going way back.
Yup, and they are my favorite style of ford engines. The 352 I tuned up would spank any of this stock fuel injection crap today.
Adrianspeeder
Old Oct 23, 2005 | 07:17 PM
max mitchell's Avatar
http://www.fordracingparts.com/downl...nginetypes.pdf
Old Oct 23, 2005 | 09:36 PM
fivefour's Avatar
It has nothing to do with Chevy nomenclature. It's not a big block. It's not a small block. It's a Modular.
Small block Fords are the 221, 255, 289, 302 (aka "5.0"), 351W, 351C, 351M, and 400M.
Big block Fords include the FE family and the 385-series family. The FEs include the 352, 360, 390, 427, 428, as well as a few others. The 385s are basically the 429 and 460.
Mod engines are the 4.6 SOHC/DOHC, 5.4 SOHC/DOHC, and the 6.8 SOHC V10.
Old Oct 23, 2005 | 10:05 PM
Johngs's Avatar
I think momalle was right, it sounds like they are talking about replacing the SHORT BLOCK. Compare to the long block.
SB:
http://www.google.com/search?hl=en&l...ne:Short+block
and http://en.wikipedia.org/wiki/Short_block
LB:
http://www.google.com/search?hl=en&l...ck&btnG=Search
http://en.wikipedia.org/wiki/Long_block
Old Oct 24, 2005 | 08:36 AM
Scotty08's Avatar
Talking
I would think they said "SHORT" block. which refers to crank, rods, pistions, and block. long block would be the other typical reference which includes the shortblock plus heads and a few other things.
Hope this helps out
Old Oct 24, 2005 | 04:59 PM
Tun2One's Avatar
Hope this helps out
Short block does make sense. I'll ask the question again, now that I am more informed.
Thanks everybody!
Old Oct 24, 2005 | 05:31 PM
GABoyinTroupCo.'s Avatar
Originally Posted by techman1067
If I recall, one of the features that stand out between a big block and a small block is that of the crankshaft main. A small block has a series of two bolts that hold it together and a large block has a four bolt main.
Sorry, that's not right either, there are small block chevy's with four bolt mains. The four bolt mains were primarily used in towing applications such as trucks but were in some cars when the GM God's just decided it was desirable.
Old Oct 24, 2005 | 05:39 PM
Alright, the motor isn't a "Big" block or "Small" block it is a "modular". It has two cams and it is an interference motor which neither the "Big" blocks nor the "Small" blocks have or are. Secondly, if they were going to change the 5.4 to a 4.6 it would cause these guys such a headache that they would rather cut their own penises off rather than go about it that way. Shops are in it for fast turnaround and putting a 4.6 into a truck that had a 5.4 would be a nightmare and it wouldn't be as profitable. I agree with the previous posts it was probably a short block that they were talking about or maybe they were just dumb as hell and didn't know what they were talking about in which case I would go and find me another shop. Pick up the phone and call them back... ask them to clarify.
Old Oct 24, 2005 | 05:42 PM
I used to love outrunning the big block Cheys(454s and 396s) with my Ford . They would come up and say, "what big block Ford are you running?" and I would get to deflat them by saying its just a small block Ford, a 351 Clev. Talk about a conversation dampner!
Old Oct 24, 2005 | 07:55 PM
exx's Avatar
exx
Well technically it is a modular motor as anyhting without pushrods and modularly designed with overhead cams is, but as far as cubic inches and block size, id hardly say you can call 330 ci a big block.
