Really, Extremely, Ridiculously dumb question.
Old Oct 10, 2005 | 11:16 PM
SlammaJamma's Avatar
I have a serious question. Im about to change the plugs on my motor, but there's one problem. WHERE ARE THEY LOCATED? I feel so dumb for asking this, but, I seriously can't find them anywheres.
Old Oct 10, 2005 | 11:18 PM
bmx150's Avatar
they are on the sides of the top of the engine they have wires attached to them going to a distributor...
Old Oct 10, 2005 | 11:22 PM
Ha, thanks so much, BTW its a 99 4.6L, if it makes a diffy.
Old Oct 10, 2005 | 11:27 PM
bmx150's Avatar
then they should all be on the drivers side since its an inline 6 i have a
95 4.9I6 and its awesome. actually just washed and waxed the whole truck for like four hours tonight just got in after finding out my brother has a leaking fuel filter
Old Oct 10, 2005 | 11:45 PM
wittom's Avatar
If I remember correctly the 4.6 didn't go coil on plug untill '01, so you will have two coil packs. They are twards the front of the engine just about in line with the "valve" covers. There will be four spark plug wires from each coil pack to the plugs. Since these are OHC heads the spark plugs are much farther down in than most push rod motors. It's not too bad a job to do. There will be a bunch of stuff in your way, just be careful you don't break anything trying to move it. Also the two back plugs are under the fire wall. It's going to be a pain to get thoes out. Be careful not to break them.
Good luck!
Old Oct 11, 2005 | 10:01 AM
GEORGE4.6's Avatar
They are by the fuel injectors follow the wires from the coil packs
