reflased
Old Sep 23, 2005 | 08:23 PM
shoeynne's Avatar
reflased
i have a o5 screw with 800 miles been to shop to get sluggish respone service said all normal no codes i asked them to reflash the system they said they cannot with out a code comming up.is this true,well the truck is back in the shop today for a/c not working front end promblem and rough idle and poor fuel mileage and ,see what they say this time with it,any help thanks
Old Sep 24, 2005 | 01:02 AM
HamRadio's Avatar
Tsb
What you need to do is go in and tell them you have a throttle lag and they need to reflash your PCM due to a TSB (Technical Service Bulletin) that is out on this. Tell them TSB 04-21-14 is the one. I can send you a copy e-mail if you like. Drop me a note at w6lar@arrl.net and I will return a copy to you.
This way they can't say no to your request. If they do, then go to another dealer. To check after they do a reflash they are supposed to place a sticker under the hood that tells the version they reflashed to. This is required by law as the PCM comes under emissions standards.
Good luck!
PS: I just realized you have an '05 and this TSB is for an '04 but it still may be valid. Its worth a try.
