Is this the correct plug #?
Old Sep 19, 2005 | 10:14 PM
babyhauler's Avatar
Dealer wants 4.86 per DP plug jobber price, for my 5.4 "L" eng. Local shop that sells AC Delco & Motorcraft parts says the correct plug is only $2.60 per, which is about the same as Autozone for regular mc plugs, not D.P.
The shops MC part # is AGSF22WMF4. I have bought many AC parts from this guy & he always gives me the best price as we used to work together.
But, as he said, he did not know Ford stuff or if this was the DP plug #, but that was all that was listed for an '01 5.4 L engine. So, is this the right plug?
At 116,500 miles, do I need to change the boots also, or do I have to spend that money? Truck runs fine now, just avgs 13.5-14. MPG. Oh, the plugs in it are originals & the one I checked was @ .0070 (?)UGLY. I have the Air force one & 18" SIDO Magnaflow & I have been driving like an old man just to get 14 mpg. He also priced the front O2 sensor @ 49.98. for MC.
There is a very good local repair shop that highly recommends the Motorvac process for Ford products. The Impala SS sites that I used to frequent had a huge thread with hundreds of extremly happy SS & Caprice owners that had used the Motorvac process to pass emissions or just run better. I have found a few results here, but mixed results. Thanks for your input to the Ford rookie.
later,
Old Sep 20, 2005 | 08:27 AM
projectSHO89's Avatar
You can look the most current Motorcraft part recommendations at www.motorcraft.com
DP plugs are no longer the official Motorcraft replacement parts. Now it's a "fine-wire" plug.
Steve
Old Sep 21, 2005 | 10:01 PM
babyhauler's Avatar
I called another dealer & he gave me that part #. So I guess that means that is the same as the original plug. I just want to make sure I use the correct new ones.
Old Sep 22, 2005 | 07:56 AM
Johngs's Avatar
That part number you listed is the correct part.
Old Sep 22, 2005 | 11:15 PM
babyhauler's Avatar
