F-150 5.4 and 4.6 Throttle Response INFO!
OK everyone I found a thread about the 5.4 throttle response and Paid Motorcraft $10 to access the TSBs for 2005 F-150s... Here it is...
I hope this helps someone out there. I only have access for another 48 hours, but here is the detailed info on the 5.4 3v fash update chingas... I asked my friend that works at the Ford dealership with a new 05 screw lariat and he said it made it get better gas mileage and performace for sure.
I coundnt include everything I wanted because my thread was so long...
FORD: 2005 F-150
LINCOLN: 2006 Mark LT
This article supersedes TSB 05-18-9 to update the model years.
ISSUE:
Some 2005 F-150 and 2006 Mark LT vehicles equipped with the 5.4L 3-valve engine and built prior to 4/20/2005, may exhibit the malfunction indicator lamp (MIL) on, or various driveability conditions as follows:
F-150/Mark LT
Slow throttle response
Hesitation on acceleration (cold)
Fast engine idle after cold start (does not apply to California emissions vehicles)
Diagnostic trouble codes (DTCs) P0351-P0358
Hard start/long crank/cranks-no start
Mark LT Only
DTC P061B with P2106
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration level using WDS release B36.11 and higher or B37.2 and higher. This new calibration is not included in the B37 CD. Calibration files may also be obtained at www.motorcraft.com.
NOTE: THIS TSB SHOULD NOT BE PERFORMED IF P2106 AND P2135 ARE BOTH PRESENT TOGETHER. REFERENCE THE ONLINE VERSION OF THE PC/ED MANUAL.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
051901A 2005 F-150, 2006 Mark LT 5.4L 3V: Check For Diagnostic Trouble Codes And Reprogram Powertrain Control Module (Do Not Use With 12650D, 12650D84) 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
RECALEM 04
FORD: 2005 F-150
ISSUE:
F-150/Mark LT
Mark LT Only
ACTION:
WARRANTY STATUS:
DEALER CODING
RECALEM 04
Heres the full list of TBSs....
Technical Service Bulletins
2005 F-150 - US (English)
05-19-1
MIL ON - VARIOUS DRIVEABILITY CONDITIONS - 5.4L 3-VALVE ENGINE - VEHICLES BUILT BEFORE 4/20/2005
05-18-12
MIL ON WITH DTC P061B AND/OR P2106 AFTER COLD START AND RAPID TRANSMISSION GEAR ENGAGEMENT - VEHICLES BUILT 8/23/2004 THROUGH 1/15/2005 - 5.4L 3-VALVE ENGINE
05-18-7
WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS
05-18-3
DIAGNOSTIC TROUBLE CODE (DTC) P0340 AND/OR P0344 - 5.4L 3V ENGINE
05-16-12
SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
05-16-11
SAFETY BELT RETRACTION SPEED
05-15-8
TICKING AND/OR KNOCKING NOISE FROM ENGINE - 4.6L/5.4L 3V
05-15-1
CLICKING/TICKING NOISE FROM STEERING COLUMN - VEHICLES BUILT BEFORE 5/31/2005
05-14-4
WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-14-2
HEADLINER BUFFETING/RATTLE NOISE - VEHICLES EQUIPPED WITH ROOF-OPENING PANEL AND BUILT PRIOR TO 6/1/2005
05-13-4
HARD START/LONG CRANK, ROUGH IDLE, ENGINE IDLE MISFIRE - MIL - DTCS P0300 THROUGH P0308, P0171, P0172, P0174, P0175, P0316, P2195, P2196, P2197, P2198
05-13-1
SHUDDER/VIBRATION ON MODERATE TO HARD ACCELERATION
05-12-6
REAR AXLE NOISE REPAIR
05-11-9
REMOVAL AND INSTALLATION OF REAR BOLT-IN GLASS - SERVICE TIP
05-10-19
INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
05-10-15
MIL ON, MISFIRE DTCS, SPARK KNOCK - VEHICLES BUILT THROUGH 4/25/2005 - 5.4L 3V ENGINE
05-10-12
HARSH 3-2 DOWNSHIFT BETWEEN 17-25 MPH (27-40 KM/H) - NO DTCS - 4R75E AUTOMATIC TRANSMISSION - VEHICLES BUILT BEFORE 4/20/2005
05-10-11
WHITE FLAKES COMING FROM A/C VENTS
05-9-23
STEERING COLUMN RATTLE/CLUNKING WHILE DRIVING OVER ROUGH SURFACES AND WHEN TURNING THE STEERING WHEEL
05-9-18
DISCHARGED BATTERY - CHARGING SERVICE TIPS
05-9-3
INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-6-21
FRONT END SHUDDER/VIBRATION WHEN BRAKING - VEHICLES BUILT BEFORE 11/18/2004
05-6-4
FALSE PARKING AID WARNINGS
05-5-5
KEYLESS ENTRY KEYPAD INOPERATIVE
05-4-3
COOLING FAN CLUTCH NOISE - VEHICLES BUILT PRIOR TO 10/1/2004 - 5.4L AND 4.6L ENGINES
05-3-11
MIL AND/OR DTCS P0172, P0175, P0171, P0174 - THROTTLE PEDAL RESPONSE/TIP IN HESITATION - VEHICLES BUILT PRIOR TO 1/31/2005 - 4.6L ENGINE
05-3-10
SAFETY BELT WEB STOP BUTTON SERVICE
05-3-5
ROOF DITCH MOLDING LOOSE - VEHICLES BUILT 1/3/2005 THROUGH 1/4/2005
05-3-1
MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-26-18
FRONT DOOR TRIM APPLIQUE REMOVAL
04-26-17
BODY REPAIR PROCEDURE USING MIG WELDING FOR WELD BONDING
04-26-16
WELD BONDING PROCEDURE
04-26-6
CLUNK OR BUMP WHEN STARTING FROM A STOP
04-25-17
MAGNESIUM ALLOY RADIATOR CORE SUPPORT - UNIQUE HANDLING AND REPAIR PROCEDURES - SERVICE TIPS
04-25-8
1ST ORDER VIBRATION FROM THE DRIVELINE AT HIGHWAY SPEEDS
04-25-7
VEHICLE/STEERING WHEEL VIBRATION AT 50 MPH (80 KM/H) OR HIGHER - STEERING WHEEL NIBBLE AT 65 MPH (105 KM/H) OR HIGHER
04-24-24
CAMSHAFT AND LASH ADJUSTER DESIGN CHANGE - 5.4L 3V ENGINE
04-24-20
LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
04-24-14
GENERAL PCM PROGRAMMING PROCEDURES
04-24-5
REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-24-3
LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE
04-23-10
AUDIBLE DRIVELINE MOAN ABOVE 45 MPH (72 KM/H) DURING ACCELERATION OR COASTING - VEHICLES BUILT 8/20/2004 TO 10/4/2004
04-16-1
ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
04-9-6
BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
05-19-1
05-18-12
05-18-7
05-18-3
05-16-12
05-16-11
05-15-8
05-15-1
05-14-4
05-14-2
05-13-4
05-13-1
05-12-6
05-11-9
05-10-19
05-10-15
05-10-12
05-10-11
05-9-23
05-9-18
05-9-3
05-6-21
05-6-4
05-5-5
05-4-3
05-3-11
05-3-10
05-3-5
05-3-1
04-26-18
04-26-17
04-26-16
04-26-6
04-25-17
04-25-8
04-25-7
04-24-24
04-24-20
04-24-14
04-24-5
04-24-3
04-23-10
04-16-1
04-9-6
Originally Posted by doctord75
or the cam phasers as that was the cause for my ticking...
My 5.4 sounds more like a diesel than a gasser at idle. Definitely didn't sound like that in my last one.
Originally Posted by quackrstackr
Have you had anything done about it?
Yes, when I took my truck in they replaced the cam phasers on the right side and that took care of the noise.. Mine sounded diesel like as well and now all is smooth..
Dave
