Someone Please HELP!!
Old Sep 6, 2005 | 11:50 PM
bigchimi's Avatar
Angry Someone Please HELP!!
I have a 97 F150 4.6 4x4 I have about 160k miles on it, and it has run fine until about a week ago. It got a little hotter than it usually does. So, I went to put water in it, and I noticed that the water had oil in it. I checked the oil and the transmission fluid, and neither one of them have water in them. I did a flush and fill, and drove it around the subdivision, and then the check engine light came on. The parts store says that the code is for a misfire on cylinder 1. So far, I have put all new autolite plugs in with no improvement. I have moved wires and coil packs, without moving the problem. I did a compression test and that checked out fine. I am out of ideas. Someone please help!! thanks
Old Sep 7, 2005 | 07:34 AM
Polydorus's Avatar
I'm changing a water pump on my 1978 Ford tractor right now. I was surprised how much fluid there was in the block after I took the old pump off. At least on this tractor, just flushing the radiator does not get everything out.
Old Sep 7, 2005 | 09:48 AM
JMC's Avatar
JMC
25 Year Member
Have your cooling system checked for combustion chamber gasses. There could be a leak that is allowing gasses, along with some engine oil, to enter the cooling system.
JMC
Old Sep 7, 2005 | 11:20 AM
Polydorus's Avatar
Where can you get something like that done and how much would it cost? TIA
