4.6L cutting out at full throttle ?
Can a fuel pump cut out at full throttle but still work great at under medium load just fine. i replaced the fuel filter and still there when i get on it hard. You can feel it buck in and out. Has 115K on the motor.1999 F150 Same wires,coils,ect.
On FI engines, missing at WOT usually cannot be a fuel pump stoppage because the result is not 'instant' fuel loss because the pressure dosn't drop to zero instantly.
More likley plugs, wires, coil packs that will instantly cause a missfire when they have a fault.
