97 Lincoln Town Car E-Fan??
Old Sep 5, 2005 | 03:14 PM
kr1mson k1ng's Avatar
I have an 01 5.4L. I want to put an e-fan in it, but don't want to spend mucho $ for a fan. I can get an e-fan from a 97 lincoln town car for pretty cheap. It's an 18 incher with a shroud.
Will this fit??
Old Sep 5, 2005 | 06:09 PM
Pestco1's Avatar
pretty sure the fan will "fit" physically. How were you going to run this fan? seems like I would just bite the bullet and purchase a professionally put together kit for something so important.
Old Sep 5, 2005 | 06:41 PM
Faster150's Avatar
yes it will work most stock 18" electric fans from ford push 2100CFM to 4000 CFM which is more then adequet for up to a 400 HP engine... so yes it will work. im likely going to do the same but i want pusher fans so imma likely get some twin 2500CFM fans and mount them on front of the AC condensor. since the fans always push more then they can pull.
Old Sep 6, 2005 | 10:20 AM
I hear ya...but I bought an efan kit for a previous truck. They are not worth the money. $400 for 2 fans and a relay???????? Gimme a break. I will never spend that much again. I don't need 5000 CFMs. I can get a fan from a used car for $35 and I don't know how much a relay costs....but whatever.
As far as fit goes....will the shroud cover the radiator? I can take measurements, but I've been too lazy lately
Old Sep 6, 2005 | 10:23 AM
oh, and the fan is a dual speed fan. I'm not sure of the CFM rating though.
Old Sep 6, 2005 | 12:47 PM
Faster150's Avatar
400 for two fans and a relay sounds like mike troyer setup right? u can 16" get 3300CFM fan from zirgo on ebay for 94 bucks
http://cgi.ebay.com/ebaymotors/ZIRGO...73239888QQrdZ1
which is more then plenty for your engine and relays are 50 bucks at the most if u buy a kit.
Old Sep 7, 2005 | 12:08 PM
Pestco1's Avatar
There is a little more to the controller than a relay. If you have a/c then it is even more complicated. If the fan runs all of the time at full speed then your engine will never come up to temp. Of course, if it doesn't come on when it needs to be than you get the opposite problem. The controller is a thermostat that monitors engine temp and turns the fan on and off as needed. It has an overide that turns on the fan at a lower speed or just one fan in the case of a dual fan set up for the A/C. The fan in the tc is controlled by the engine computer and a fan module. you would need to somehow duplicate that set up in your truck.
Old Sep 7, 2005 | 12:11 PM
Faster150's Avatar
heres teds way of doing it
http://home.comcast.net/~therazy/Ele...rsionPage.html
