Sea Foam
I have a 92 F150 5.0 with E4OD , ran a can through my intake and put one each in my gas tanks . Was reading the can and said you could add to your oil , Anybody have in thoughts on that? Oil should lubricate and adding Sea Foam may cause the oil to break down.Engine has 93k on it .
Sea Foam
You add it right before you change the oil. Put it in and run the engine for a few then shut off and change oil. It cleans all the crud and sludge out. It is not to be added to the oil and left in like an additive you leave in.
Here is the technical breakdown for you guys that keep stuffing this product in your engine.
http://www.seafoamsales.com/pdf/MSDS_SFTT_US.pdf
Pale oil is a light oil
Naptha
IPA= alcohol.
Naptha
IPA= alcohol.
Originally Posted by mahoney22e
ok that means nothing to me labnerd. Now in english what does this mean?? i have used seafoam in my two vehicles for years, am i doing more harm than good?
