Should I buy this engine
Old Aug 6, 2005 | 12:25 AM
jdoc's Avatar
My 99 4.6W f150 has the notorious pass. side head gasket leak and I'm ready to replace the engine. I talked to a guy that sells engines and he sent me the email below. Does this all sound right and do you guys think its a good deal. Thanks for any input.
"59k miles $775 plus freight for a 96 Ford Crown Vic engine. Long block is the same as your trucks engine. Would possibly have to use the intake/exhaust manifold off your existing enigne. "
Old Aug 6, 2005 | 12:33 AM
LCDRWorth's Avatar
Personally, I wouldn't go with an engine that old for a 99 model truck. Could run into more problems than it's worth. But that's just me.
Old Aug 6, 2005 | 01:13 AM
jdoc's Avatar
yeah I know what you mean but im scared to buy a 99 4.6 because of the TSB on the pass head gasket. I dont really want to go thru this again.
Old Aug 6, 2005 | 02:34 AM
fourstakers2's Avatar
too old of motor?
greetings,
my 2002 4.6 spun a main or two. i found a 2002 5.4, and it was almost a direct replacement, even used the 4.6 harness. spent a little bit more and got a 7k mile motor with a lifetime warranty from a local used parts broker that has been around for 30+ years. WARRANTY MEETS SHOP RATE, WITH PARTS! I think i can even get the heads repaired/replaced if a plug blows out. the warranty was 40% of the total price. even got to keep the 4.6, incase i get to feeling adventurous and bored. just food for thought....
Old Aug 6, 2005 | 12:02 PM
LCDRWorth's Avatar
I'd just look around and get one maybe a year older or a year newer, but not quit that old. With the 99, you should be able to go up a few years (2002 probably). Good luck!
[EDIT]
Oh yea! Try eBay. I think I found a couple of engines on there the last time I looked. Might be able to get a good deal there. Couldn't hurt, right?
[END EDIT]
Old Aug 6, 2005 | 12:06 PM
LCDRWorth's Avatar
You know what, I couldn't help myself. I was so bored I did the eBay searching for ya. Found a few engines you might be interested in, depending on how much you want to pay.
http://motors.search.ebay.com/f150_E...Z6028QQsaspiZ2
Old Aug 6, 2005 | 02:45 PM
Faster150's Avatar
get an aviator motor :-p 32V 4.6L
