I A C Valve
I A C Valve
Does anybody have a pic of the location of the IAC valve on a 99 5.4 Im looking at my idiot guide and dont see what there showing me Im thinking this is my foghorn problem help please ? Part number would be great also
This is a pic of the throttle body. See the IAC? I got this pic from somewhere else, so sorry for all the extra crap. BTW, I'm not sure, but I think that some throttle bodies are different and the IAC is at a different part of the TB, but it still looks exactly the same.
Thanks i think I found it its behind the throttle body on mine I was thinking of replacing But ill try cleaning it all first. Looks a little cramped as far as getting the bolts out but ill give it a shot.
I don't know about the 5.4, as I've got a 4.6, but i just took the IAC off. Easy as anything else. Sprayed some carb cleaner in it really good and a little down the ports and so far, my truck hasn't quit on my like it had been doing. Cleaning it is probably all it needs.
yeah the 4.6 is alot easier. The IAC is on the top of the engine rather than in the back like the 5.4. It is really worth it to clean the EGR ports if you do have the IAC taken off. GO ahead and spend the extra hour. ITs really worth it.
i take a test tube cleaner, or a gun barrel cleaner and go after my EGR ports then i polished the main inlet for the EGR as best i could with the dremel and wire brush to keep any excess from sticking and gunking up again
I took the IAC off of my 03 5.4 Screw and it was nothing nice. I used a 1/4 inch drive rachet and 5/16 socket. It was extremely slow going with little room to work the rachet. Once I got it off the new one when on in little or no time. The bolts went all the way in by hand. My old on was not dirty at all, just had some carbon build up on it. I changed the pvc valve also. Now I will see if my mpg goes back up to where it was. I would recommend a long flexible extention to anyone performing the job.
