i found some oil on bottom of tranny case. what does this mean
i was under my truck today and were the rubber inspection disk is on the tranny i found some motor oil ther little but it was there. i looked up toward the passenger side and on the start was some oil also. where did it come from? under the hood no leaks at all. none.
what doe it sound like to you, truck has 51,000 on it right now
We went thought this a while ago. Check out this thread.
Also don't be scared to use the search.
dammit Lee, every time I click on one of your links it fries my cookies for this site. Now none of the threads I've read are marked as read. Last time I had to delete all my cookies, log out and wait till morning before coming back to the site. Grrrr!
Add the 'www' to your link! You just have 'http://f150online.......' instead of 'http://www.f150online....'
^^ the link works for me. when i put a link in i go to the page i am going to link and then copy the address right out of the address bar. I don't know why it doesn't work for you?
valve cover or rear main seal
gets on the tranny by the wind of driving
keep an eye on your oil level anyway
...zap!
The link worked, but it showed me as not being logged in. That screwed up my cookies set for this site. Once again I had to log out, clear cookies and wait a half hour before logging back in. Now everything is working for me again.
Steve has this site mirrored, 'http://www.f150online' and 'http://f150online'. You use one and I use the other. When I click on your link, it fries my cookies for this site. I was making you aware of it. That's all.
ahh, that makes sense. yesterday i was getting logged out.
Let me save the www one in my faves.
stop leaks generally do not work. what they do is soften and swell the seals. I think you may have a head gasket leaking. you can either let it be or spend the cash and have it replaced.
But first you need to find exactly where the leak is.
