Spark Plug part number confusion
Old Jul 20, 2005 | 10:36 PM
BluMan1's Avatar
Registered User
Question Spark Plug part number confusion
Hi,
I've done several searches and I'm confused over Motorcraft spark numbering for my 2001 F150 4.6. My manual shows AWSF32EE or AWSF32PP. Supposedly, they changed the numbering to either AGSF32PM, PM4, or FM. All I want is the new number for the double platinum replacement. Thanks.
Old Jul 20, 2005 | 10:41 PM
lees99f150's Avatar
on my 99 the original motorcraft were AWSF22E and i replaced them with Autolite double platinum APP103
either this will help or confuse you more
Old Jul 21, 2005 | 05:10 PM
ptlmbutler's Avatar
if you do a forum search on this you can get your answer. I know I have read it before somewhere on here, just can't remember it off the top of my head.
Good luck
Brian
Old Jul 21, 2005 | 06:31 PM
BluMan1's Avatar
Registered User
I have done many searches. Some of the responses indicate the AGSF32 with the "FM" suffix, some with the "PM" suffix. Others have asked the question as to whether the FM or PM plugs are double platinum with no answer. Given the spark plug blow out problem, I don't want to take any chances with Autolites or any other non-orignial equipment plug.
Old Jul 21, 2005 | 11:03 PM
lees99f150's Avatar
Autolites and motorcraft are both the same. You need,
AUTOLITE double platinum APP764; Gap .054
Old Jul 21, 2005 | 11:28 PM
lees99f150's Avatar
If you look in your owners manual you will find the correct motorcraft number. If you don't have a manual then you can download one for free here.
http://www.genuineflmservice.com/default.asp?page=E4
Old Jul 22, 2005 | 07:42 AM
projectSHO89's Avatar
His owner's manual is likely out of date for the spark plugs.
Current Ford-recommended service replacement part numbers can be looked up at www.motorcraft.com
The newer fine wire plugs are sinlge plats. However, their design eliminates the need for platinum on both electrodes, including on waste spark systems.
Steve
Old Jul 22, 2005 | 09:22 AM
PONY_DRIVER's Avatar
That's what I just put in my 01 Screw.
Old Jul 29, 2005 | 03:42 PM
jjmIII's Avatar
Exclamation
Do others agree??
I was seeking out MotorCraft, but my Uncle's Auto Parts store carries Autolite. I will just get Autolite if they are the same.
Thanks for any help
