Walmart Performance Products!!!
all i did to plug the inlet on the intake elbow is pull the boot off the stock PCV line and stick a good size bolt in the end then just put the boot back on the inlet and ur set.. the PCV filter was about 10.20 with tax at walmart!!!... im an official a member of the walmart performance products performance team!!! woot.....
Originally Posted by Red03SVT
just get their neons and you're all set!
-Mike
-Mike
i looked and the exhaust tips werent the right size and no euro lights for my truck nor could i find a wing to mount in the bed
... i thought walmart had everything!!
Originally Posted by Intel486
You get added performance just because it came from wal-mart too!
Should have seen if they had any flame stickers for your truck too.
yeh im thinking about gettin some seat covers for my leather interior that got GTR in japanese written on em!!!
Originally Posted by Jackal
...so you blocked off your PCV system? Now you are allowing unmetered air to circulate? Not good...right?
no .. the inlet onthe intake is blocked off no unmetered air can get into the intake unless it leaks paste the valve stems..
Originally Posted by GABoyinTroupCo.
Explain to us exactly what performance aspect you are gaining here. Seems to me like you wasted ten bucks.... and truly made your engine bay look like it was worked on south of the border
the PCV valve will let oil seep into ur intake causing poor combustion injectors to get clogged umm intake ge gunked up gunks up backs of valves... so by eliminating blow by oil ur fuel economy and performance will goes up... mostly just keeps ur intake system clean.
Just rebuilt my motor, and at 107,000 I had very little build up. I'll just keep cleaning mine with sea foam every so often and keep my stock PCV....I think the Ford engineers had it there for a purpose... I mean they could have saved money on production and engineering of the vaccum hoses to the PCV by just putting on a $10 Waly-World product. Sorry to knock your stuff, but I just believe you could have put ten bucks towards electric fans and got more bang for your buck. And if you change your PCV regularly you shouldn't have any oil seepage into your combustion area.
its there for emissions to burn the emissions gases that build up in the crank case. remove it in some states u wont pass emmissions laws. and i have 126,000 on my engine and compression is still stock spec. and it has original PCV valve in it... all pro mod dragsters use breathers and most all boosted engines use them also to keep oil from being sucked into the intake system and causing power loss and gunk up
One thing I do hate is why doesn't Ford put electric fans on these trucks in the first place... The mustangs get them!!! They also helped the gas mileage in the city out on my old truck.
Originally Posted by racerf150man
: 00' F-150 Supercab 2wd 4.6L
Totaled - RIP
14.59 @ 93.18mph
may she rest well in her place... happy to see the newborn in the garage tho
Totaled - RIP
14.59 @ 93.18mph
But, thankfully I was able to find exactly the truck I was looking for. Had to drive two cities away to pick her up
http://i15.photobucket.com/albums/a3...ck/ntruck3.jpg
