5.4 won't idle
Old Jul 5, 2005 | 05:27 PM
RANCH_4x4's Avatar
5.4 won't idle
I hope this is just a coincidence that I SeaFoamed the Brake Booster line a week ago.
The problem is that the truck will barely idle at all.I thought it was the IAC, but I changed it with a brand new one and no difference.
I also changed the PVC valve a week ago.
It sounds like it wants to die and the truck adds a little throttle itself to keep it alive.
I'm NOT getting a check engine light so I'm stuck. The plugs are not old either, maybe 15k miles on Autolite plats.
Any ideas, please help.
Old Jul 5, 2005 | 05:36 PM
Faster150's Avatar
check the throttle position sensor... and may be the seafoam clogged up somewhere in the intake and it causing poor fuel mixture? have i tried half throttling the truck and spraying throttle body cleaner in there or B-12 as its called.. that should nock out anything. in the intake system.
Old Jul 5, 2005 | 05:45 PM
kauaid's Avatar
check your injectors
hey, check your injectors. i had the same problem last week, chased it down all week. finally pulled the injector it was clogged with white powdery stuff. i put seafoam through the brake booster, and some in gas tank the day before that happened to my truck. it's worth a look.
Old Jul 5, 2005 | 05:52 PM
Faster150's Avatar
yeh u can take it to dealership and have em do an injector flush for like 65 bucks is about what it costs
