f150 cooling problem?..
Old Jul 4, 2005 | 01:51 PM
gander's Avatar
I have a 1996 f150 with 4.9 ..the idiot temp gauge is reading in the normal range but hotter that what it used to run..I have replaced thermostat had fan clutch checked out . is it possible with the sensor?. Any advise? thanks
Old Jul 5, 2005 | 04:45 PM
bshaw's Avatar
Does not sound like a major problem. Have you check your fluid level for a while?
Old Jul 5, 2005 | 04:50 PM
gander's Avatar
re f150 cooling prob
Coolant level is fine.
Old Jul 5, 2005 | 04:54 PM
bshaw's Avatar
Only other things I can think of, is maybe it needs a flush. Had that done for a while? Or maybe a good cleaning in between the radiator and condensor is in order. Checked that out lately?
Old Jul 5, 2005 | 05:17 PM
gander's Avatar
about 6 months bk I put on a 2 row radiator and flushed system
Old Jul 5, 2005 | 10:26 PM
2005F150SC's Avatar
The coolant sensor works off of resistance. It could be failing or there could be a electrical problem coming about.
