Exhaust Leak or Paranoia?
Old Jun 23, 2005 | 11:58 PM
Brian 5.4's Avatar
Ok, with this new truck it seems that I am just looking for something wrong. Being the extreme perfectionist that I am, things bother me on the level of often being unhealthy.
The latest "problem" I seem to have discovered is what I would call a very faint "hissing" sound under acceleration. The sound seems to be more closely related to the amount of throttle applied than RPM-related. The best way I can describe it is as if someone is saying "shhh!" very quietly. It is very faint and virtually undetectable unless you listen for and try to hear it. Is what I am hearing just the moving parts of a motor or in fact some kind of leak. It is not pinging or knocking, but rather sounds like air escaping from or being drawn into somewhere. I looked briefly for exhaust leaks but didn't see any upon first glance. I have been experiencing some faint pinging under load lately and intend to clean my TB and EGR ports soon to help remedy that. Is it possible that the wooshing I am hearing is somehow related? Should I just drive and forget about it? I understand how corny and obsessive this sounds, but any input is appreciated.
Brian
Old Jun 24, 2005 | 12:02 AM
Faster150's Avatar
might just be intake noises like air boving accross the MAF or air moving across the throttle plate or the IAC. but its likely not and exhaust leak u can usualy smell and exhaust leak but u can have a friend put the brake on and give it a litle gas to put it under load and check for any leaks along he manifold. or check ur cat back to see if u have an exhuaust leak. but its prolly nothing u should also check and vacume lines for leaks
Old Jun 24, 2005 | 12:08 AM
Brian 5.4's Avatar
Thanks for the response.
I have done some searching and found that many people seem to have noises and such, but also CEL and rough idle/hesistaion/missing. My truck idles smoothly and runs fine with no CEL or codes. I'm planning on cleaning the EGR and throttle body and replacing the fuel filter when I get some time( hopefully this weekend) and maybe that will make an improvement. If not, I suppose I should forget about it. I know its hard to diagnose noises over the internet, but again, any input is appreciated
Old Jun 24, 2005 | 10:19 PM
GABoyinTroupCo.'s Avatar
Talking
Many time these trucks are also none to have a slight noise such as you described that come from the injectors. Just my 2 cents worth.
