having trouble with engine
Old Jun 1, 2005 | 12:33 AM
mundt34's Avatar
Hey I have a 1995 f150 im having a little problem with my truck that so far has cost alot of $. My truck when not moving idles fine but when I accelerate the truck shakes like it isn't getting any gas. I have replaced the fuel injectors, throttle positioning sensor, coil, ignition modual, it's had a tune up, and a new air filter, and the fuel pump has been tested o.k., the idle air valve has been cleaned out. If any one has any suggestions please help.
Thanks,
Kevin
Old Jun 1, 2005 | 12:45 AM
racerf150man's Avatar
o2's, fuel filter, run seafoam in the gas to clean out injectors, run it in vac lines to clean them out, check pcv, do a search about cleaning throttle bodies.
Old Jun 1, 2005 | 12:54 AM
mundt34's Avatar
I have installed a new feul filter and ran gas treatment through the gas the injectors are brand new. Ihavent cleaned the throttle body yet.
