k&n or air raid cold air intake
Old May 26, 2005 | 12:25 AM
antelope555's Avatar
The questions that i have are, does the k&n air intake use all the factory mass air flow sensor, does the air raid use it as well. Does the air raid attach better? was there any power/ mpg gain?
thank you
antelope555
Old May 26, 2005 | 06:31 AM
jhoparmy's Avatar
You should notice a power gain going to the K&N or Air Raid. I have the K&N FIPK and love it. It uses the factory mass air flow sensor, but you can still change it if you want. I don't know about the Air Raid, but for the price, I'm sure it still uses the stock mass air flow sensor. The system is very easy to install. Hope this helps.
Old May 26, 2005 | 07:41 AM
jhogan's Avatar
From what I've read, as I don't have a cold air intake on my truck, with a 2004 F-150 you're going to want either the Airaid or the Air Force One. The K&N apparently make the engine run too lean. Guys are saying the power gain is noticable.
