Will not start
Old May 18, 2005 | 03:33 PM
Bubbadewsky's Avatar
Will not start
I have a 2000 Explorer and it will not start unless I press my foot on the accelerator pedal. As long as I am pressing on the gas pedal all is well---------when I let up on the pedal the engine dies. What is wrong here???
Old May 18, 2005 | 03:37 PM
RockyJSquirrel's Avatar
When was the last time you changed the fuel filter?
Old May 18, 2005 | 03:46 PM
It runs good as long as there is slight pressure on the gas pedal---- let up on the gas and it will not idle, just dies
Old May 18, 2005 | 03:54 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
If that motor has an IAC which I don't know if it does,
then give the IAC a good whack with a blunt object.
If it idles after that, then you got a fouled IAC.
Replace or clean, if in fact that motor has one, which I don't know if it does.
Old May 18, 2005 | 03:59 PM
JMC's Avatar
JMC
25 Year Member
You might have a vacuum leak. That would explain the stall at idle. Have you done anything to the engine just before it developed the symptoms?
JMC
