As I thought, air box "mod" a wash
on a more seriouse note...i thought and still think that the main improvement of the airbox mod will come with the K&N filter. but the exposed filter should help a little as well. throw a K&N on there and see what happens
Support string, $0.38 cents Pie Pan and Panty hose $ 2.29 the look on all my buddys faces when I opened the hood. PRICELESS, for everything else there is the Recover Card, from the makers of Screw'it'alls the everyday tablet when you just need a break
IMO try to maintain the OUTSIDE air intake. Underhood is unpredictable.
Wow I just had a mental pic, If I took 2in pvc pipe. Drilled 2 1/2in holes on either side of the bed. Ran the pipe down past the trany, with a Y of course back up through the bed. Up past the cab from the bed. With (2) 90's pointing foward (towards the hood) paint them Red, place a cherry bomb sticker on both. Wow the ram air would rock.
Nah, but someone will.
This is my first post, so please bear with me. I did the same basic airbox mod that was posted on this site. I have a 2000 F150 XLT. I have a K&N replacement filter on it. There was definitely an increase in intake noise, but that was something I was going for anyway. I have felt a bit of a boost in the low end. I have been monitoring the engine temperature at idle and at speed, and I have not seen much difference. 10-15 degrees perhaps. I will try and get a few pics of it posted for all to see.
now as far as the back woods garage mod that you suggest bhudoff....I was thinking of trying something like that myself. I will let you know how it turns out....or if I blow it up.
