Gas Guage
Old May 6, 2005 | 01:10 PM
ftblryan's Avatar
Gas Gauge
My gas gauge is exponential, like the needle goes down fast then slows the closer it gets to empty. So it says i have a quarter tank left but I filled it up and it said i have 15 gallons left with a 25 gallon tank. Is this normal, my moms 4runner had that problem too but not the extent that I do. I guess its kinda a blessing cause i won't run out of gas, but just wondering what is causing this.
Old May 7, 2005 | 01:15 AM
Schism9's Avatar
You should have about 3 gallons left when you hit E as a reserve(I believe), and this is probably part of the reason why it is not so accurate when it says you have 1/4. You could always ask the dealer if it could be adjusted/fixed.
Old May 7, 2005 | 07:19 AM
minimustangs's Avatar
f/g
I've noticed on most of my Ford's ('98 F150, '94 Mustang, '87 Ranger, '68 Montego, '70 Torino) I seem go through the bottom half of the tank faster than the top half. Almost always a fill-up causes my needle to indicate an amount beyond full...
Steve
Old May 7, 2005 | 08:14 AM
Johngs's Avatar
You have anywhere between 3 and 5 gallons left when the fuel light comes on.
If you look at the tank, you will notice that is is larger at the top and then gets smaller about half way down. My truck does the same thing, I get nearly 200 miles to the half mark, then only about 100-130 to the second half.
Although, 15 gallons left at the 1/4 left mark is kind of odd...
Old May 7, 2005 | 03:29 PM
jimk-nj's Avatar
I have a 30 gallon tank, when the fuel light comes on, I have 4 gallons left, very consistent.
I agree with Johngs, 15 gallons at a quarter tank is odd.
Old May 8, 2005 | 02:35 AM
ftblryan's Avatar
yea and now it appears i have burned through 12.5 gallons in 3 days driving to school about 5 miles and back each day. This is very confusing
Old May 8, 2005 | 03:02 AM
bryanfeelsgood's Avatar
2.5 MPG?? Is this just based on your messed up fuel gauge, or actual data? B/C that is serious!
Old May 8, 2005 | 02:46 PM
ftblryan's Avatar
this is based on my "faulty" gas guage so i hope to god its not right
