87 F150 EFI IL6 no spark
Old Apr 2, 2005 | 03:23 PM
55bird's Avatar
Truck stalled while plowing. In the past it was hard to start a couple of times after turning it off. It's getting fuel. Replaced plugs, wires, dist. cap, rotor and coil, but still no spark. Can hear the fuel pump when the key is turned and it cranks over no problem. Also replaced fuel filter, in line fuel pump and fuel sending unit inside front tank. Rear tank has been removed. Anyone with any ideas to check next?
Old Apr 3, 2005 | 10:48 AM
masseyman's Avatar
Replace the ignition module on the side of the distributor. It is held on by two hex head screws. You will need a special socket type tool to remove and replace this.
Old Apr 3, 2005 | 01:33 PM
55bird's Avatar
Thanks Massey. I'll let you know what happens.
Old Apr 4, 2005 | 03:37 PM
55bird's Avatar
Thumbs up
That did it!!!!! Thanks for the information. Just to close the loop on this subject: Ignition module at Autozone costs $30.99 and while you're there, pick up a 5.5mm, 1/4" drive, deep socket to get to the hex heads bolts (2 of them) holding the unit onto the distributor.
Old Apr 4, 2005 | 10:27 PM
nah2323's Avatar
great post. good followup.
Old Apr 6, 2005 | 01:24 PM
cscarrett's Avatar
I had the very same problems.I replaced everything you did and still no spark.Any ideas would be greatly appreciated.
Old Apr 6, 2005 | 11:14 PM
nah2323's Avatar
check and see if your coilpack is getting 12v with a testlight or a voltmeter. im not sure what color the wire is, but ground one end of the tool that you use, and poke the other into the back of connector while the key is in the ON position. if you get no juice, check fuses, and for any loose wiring connections.
Goodluck.
