oil change
Old Mar 30, 2005 | 04:49 PM
billboats's Avatar
oil change
2001 screw 72540 miles what oil 5w20 or5w30? thanks for any info.
Old Mar 30, 2005 | 05:04 PM
Faster150's Avatar
u can use either but 5w30 is cheaper
Old Mar 30, 2005 | 05:11 PM
texas94FS's Avatar
With the mileage on the vehicle and the summer coming soon, go with the oil that has the higher viscosity for better protection. When the oil heats up it gets thinner but if it gets too thin, you're in some serious sh#t.
Old Mar 30, 2005 | 07:16 PM
Johngs's Avatar
Either will work fine...
Old Mar 30, 2005 | 08:24 PM
ericsmith32's Avatar
I'd use Havoline 5w-20 you won't be disappointed. I just switched from Motorcraft 5w-30 and got tired of the poor mileage, and unresponseiveness of it. I ran Mobil 1 5w-30 before and Havoline runs just as good as it did if not better. Really any 5w-20 is good all UOA's are coming out just a good as 5w-30. Good luck. Eric
Old Apr 1, 2005 | 09:26 PM
Brian42's Avatar
The 5W is the important part. 20 or 30 depends on the weather you're going to encounter over the next few months. The 5W is important because the newer engines have much tighter tolerances and need the thin weights to flow through all of the oil ports, especially on start-up.
Old Apr 1, 2005 | 11:12 PM
Schism9's Avatar
Just don't use 5w20, only reason ford changed it to that is cause it get's maybe .5-1mpg better. It is thinner.
