upstream 02 sensors 97 F150 4.6L
Does this look like the right part to replace the 2 upstream O2 sensors on my 97 150 XLT w/ 4.6L? My mileage is getting really lousy, and with 84K miles I am debating replacing these things, even though there is no check engine light...
http://www.rockauto.com/ref/Motorcra...tml?dy-832.gif
It is the right part, you can verify under it "catalog" at www.motorcraft.com
At 84k, you should replace them. The upstream ones are almost a maintenence item and should be replaced every 40-50k. I don't know what rockauto wants for them but you can get "Bosch" ones at Pepboys for around $50 each (Bosch is oem to Ford).
Thanks, I see that the local Advance Auto parts has them for $43. How hard are they to get at? Easier to take off the wheels and go in through the fender wells, or from above? Or go underneath? I do have the special socket someplace, although the last time I replaced one of these was on my Nissan, and after buying the socket, I found that an open end wrench was all I could get on the thing anyway...
There are a few posts on installation, here's one for a 5.4 but I think yours should be very similar:
https://www.f150online.com/forums/sh...hreadid=190863
If I could do it, you can, too
I just had to crawl under my truck, pretty straightforward to do.
