Help on 91 ford
Hmm I'm not sure, but you might try this thread...
https://www.f150online.com/forums/sh...&threadid=5621
Never mind that is says 5.4L...The trick seems to of worked on my wifes 4.0 V6 last night
Did you check the Fuel Pressure? Im sure you know a weak fuel pumps symptoms, but a bad Fuel Pressure Regulator can do some really wierd eratic and unpredictable stuff.
91 right? Those have a control module on the base of the distributor I think. If you have done the tuneup and everything else checks out I would look there. My mom had a ford LTD that that thing went bad on. It would run fine till it warmed up then it would run like it was on 2.5 cylinders or something. It was bad. Took us forever to figure out what it was. It was an expensive little devil though as I remember. Might want to get some more imput. I read the last post on the other board you linked and they said something about the code being for a air intake sensor. I'm not sure but that could cause weird things to happen as well.
Some thoughts
Some thoughts
Originally posted by Donkc7pah
i will try that
And to let you guys know the code was a 332 which is EGR flow Insufficient
i will try that
