Spark?, Fuel?, Something else???
Old Oct 28, 2005 | 08:03 PM
jlford's Avatar
No it starts back up normally. Not like a loss of battery power. I have been searching this forum and other for a while trying to find a solution to this problem. Does a crankshaft position sensor problem seem like a potential source?
Old Oct 31, 2005 | 06:24 PM
jlford's Avatar
any other ideas?
Old Oct 31, 2005 | 06:50 PM
JMC's Avatar
JMC
25 Year Member
A problem sensor will usually set a code. On a WAG move the wire harness away from the accumulator. If something was cutting power to the PCM it would casue the gages to sweep after a restart. So it can not be that. Attach a probe to the middle wire of the TPS and check the voltage of the probe to ground. It should varry in a liniar motion between about .98v to 4.8v. If there is a break in the TPS wiring it will show in this test.
JMC
