Rebuilt motors
Old Feb 20, 2005 | 12:08 AM
My89f-150's Avatar
Rebuilt motors
looking for good deals on a rebuilt 302 anybody know any?
Old Feb 20, 2005 | 03:32 AM
MotoF150's Avatar
rebuilt motors
Dear My89f-150,,, for around $350 you can purchace a engine overhaul kit from NAPA Auto Parts and rebuild it yourself, if u can get someone to help you clean and scrape gaskets at the same time ur taking it apart and assembeling it, u can have it completed in one day. If the engine is smokiing or buring oil, maybe the "Bon Ami", or the "Dawn Dishwashing Liquid" fix might work. I would try that first.
Old Feb 20, 2005 | 04:31 AM
Gearhead99's Avatar
I think to "rebuild" the engine is going to take longer then one day.
If you're doing it yourself you'll have to check for cylinder wall taper and bore size to see how much of an overbore you're going to have to have done.
Usually .030 over will do.
Then check the crank for wear and out of roundness. To see how much the crank should be turned.
Most .010 undersize will clean them up.
Then measure ring gap, bearing clearance, chase all the threaded holes, etc.
To really "rebuild" an engine is not just throwing a "kit" in it and hoping that's all.
To purchase a rebuilt engine I'd check around with Jasper, Ford and other regional engine rebuilders. You probably have some rebuilders located in your area that are worth checking on too.
If you're going to "do it yourself" get a auto machine shop envolved and someone that knows what they are doing, so you don't just waste $$$. I've seen it done....oh too many times.
Old Feb 20, 2005 | 06:00 AM
MotoF150's Avatar
rebuilt motors
Dear Gearhead99 Most engines the bore and the crank is ok, they don't need any machining, all you need to do is replace the rings, and the rod and main bearings and seals and gaskets. Remember the old 2.9 V6 they had in the Ford Ranger? Me and a friend installed a rebuilt kit in that in one day, and thats removing and installing the engine too, what takes most of the work and time is cleaning the parts and scraping off the gaskets, what speeds that up is a good wire wheel mounted on a good grinder, that takes the gaskets off nice and clean.
Old Feb 20, 2005 | 08:36 AM
E350x2's Avatar
Re: rebuilt motors
I have had several motors rebuilt and it is rare to not have to turn the crank.I have always had the crank turned or replaced.
99 is correct this is not a one day job.
Maybe you can work a chevy in a day but it will only last a week!
Old Feb 20, 2005 | 08:47 AM
E350x2's Avatar
I can put in contact with a rebuild
Jasper is to high
Ford is way to high.
Try ATK engines they are online they quoted me 5.4 $2750.00 3 year warranty
or try Action engine in Louisville Ky talk to Tom tell him you got the referral from Mr Scott.They will ship. Do not forget about the Core issue
They have me quoted on at $2275.00 for a 5.4 .1 year warranty.
they are the same motors ATK offers built by the same company
ATK offers a longer warranty that is what you are paying for .
Or contact this guy he is honest and fair
mailto: old33auto@chouteautel.com.
His name is Barry tell him Indiana Floors LLC sent you.
All these prices are for a 5.4 so I am sure you can find yours cheaper.
Old Feb 20, 2005 | 09:01 AM
BLUEWORKHORSE's Avatar
Ive got a mean little pony motor ill sell ya for 1000 bucks. It has bout 400 ponys
Old Feb 20, 2005 | 10:44 AM
MotoF150's Avatar
Mr My89f150 didn't give much information why his 302 engine needed rebuilt, maybe the old "Bon Ami" or the Dawn Dishwashing Liquid trick might solve his problem, and he wouldn't need it rebuilt. He needs to do a compression test and a cyl leak down test just to see what his trouble is. Why spend a lot of money rebuilding an engine when a simple repair that all used car dealers do? The Bon Ami trick scours the cyl walls so the rings seat, and the Dawn Dishwashing Liquid cures the problem of the rings sticking to the pistons. It works, I have seen it done, Used Car Dealers do that all the time. Maybe one of you guys bought ur truck used and that was done to ur engine, and its working good.
Old Feb 20, 2005 | 11:40 AM
Gearhead99's Avatar
Not to get into a flame war here. But, if most engines that are rebuilt don't need the bores done or the crank done, then why are we rebuilding them.
The bores wear in a taper wide to narrow as you go down the cylinder bore. The scraping of the rings, which are usually much harder then the cast iron block, wear the bore.
The crank takes a bounding on two planes, causing the journals to go egg shape. And if the engine had any oil or dirt issues it will surely show up in the bearings that will transfer to the micro finish of the journal. This clearance, along with the cam bearings, is what controls your oil pressure. If the clearance is too large then the pressure is always down.
Anyway, if installing a set of rings and bearings works for you. I'm glad for you and wish you well.
Take care,
Old Feb 20, 2005 | 02:23 PM
Tsquared's Avatar
Re: I can put in contact with a rebuild
Originally posted by E350x2
Jasper is to high
FYI: A 96 5.0 is less than $2000 from Jasper. Check their website...
Old Feb 20, 2005 | 08:18 PM
E350x2's Avatar
Re: Re: I can put in contact with a rebuild
I shopped jasper I live about 80 miles from their home shop in Jasper In.They quoted me 3200 for a 97 5.4 triton.
maybe the quote you got was a short block 5.0 but it was not a triton.I have found thier prices high and their warrantys questionable.I had machine shop build me a motor and the guy used to run cranks for jasper.I ask him if the rumor about differnt
size sleeves in the bore was correct he said yes he said also for a while the bore would change dramaticly from 1-8.He did say they had improved since then but he would not purchase a motor from them to much money.
FYI!
Old Feb 20, 2005 | 10:03 PM
LSwhat?'s Avatar
find a used 5.0 explorer for under $800 and be done with it. I got one for my buddys mustang, and with a cam and intake change it is making 310hp to the wheels. and has been in the car for 2 years with no problem. reving to 6000 every day.
Old Feb 21, 2005 | 12:00 AM
93xlt2wd's Avatar
moto, what part of pa you from ?
Old Feb 21, 2005 | 12:01 AM
93xlt2wd's Avatar
absolutley find a 5.0 explorer motor same as in the 95 cobra's best deal around for a power house budget 5 liter.
Old Feb 21, 2005 | 03:33 AM
MotoF150's Avatar
rebuilt motors
Dear 93xlt2wd,,,, Im in the central part of the state, in between Centre, and Clearfield County,. up on Snow Shoe Mountain, not far off I 80.
