Change 5.4 MAF to Lightning MAF
Old Feb 11, 2005 | 09:18 AM
jhoparmy's Avatar
I've have been told not to use the Granatelli MAF in my 1999 F-150, 5.4 Litre. They told me it causes the check engine light to show up. They also told me to use a MAF from a 1999 Lightning. Can anybody tell me if they have tried this? Thank you.
Old Feb 11, 2005 | 10:55 AM
bigtruck311's Avatar
i had the Granatelli MAF for a year and i upgraded to a ford motersports 90mm maf like the lightnings, had no problems with the Granatelli, the 90mm reequires a difrent tune, if you just throw a lighning Maf on there your check engine light will come on you have to get it tuned for it
Old Feb 11, 2005 | 12:06 PM
weck11's Avatar
The way I understand it the MAF has to be "tuned" based on your injector size. when I switch from stock to 24lb injectors I bought a new 90mm MAF programmed to match. When I changed to 42lb injectors I had to send the MAF back to its factory to be re-programmed to match the 42lb'ers.
Old Feb 11, 2005 | 12:38 PM
jhoparmy's Avatar
Thanks for the help.
Will the Diablo Sport reprogrammer or the one from Troyer Performance take care of the tune if I opt for the 90mm for the Lightning, or will I have to do something different.
Old Feb 11, 2005 | 01:12 PM
01screw's Avatar
Yes those reprogrammers will work, just make sure that they are custom tuned for the correct maf and injector sizes.
Also, the 90mm lightning maf would be a 2001 or later. The earlier models were 80mm (i believe).
