blower pully
blower pully install
I am trying to change the lower blower pully, but I am having trouble trying to figure out how to remove the old one. Do I need a special tool? Any tips?
Re: blower pully install
The "lower" pulley which would be the crank pulley on both the Cobra and the Lightning does NOT require a puller to remove.Any aftermarket pulley will come with removal and installation instructions.
There is only one pulley on the Eaton blowers used on Ford SVT vehicles and it DOES require a special puller.
They are designed to exert force evenly on the rear of the pulley during removal, and on the front during installation. Attempt to use a typical finger type puller and you will definately have serious problems.....I have changed a bunch on both the Lightnings and the Cobras...
Jeff-
Welcome ! Add your vehicle description to your signature, profile, or within your post for accurate information. The following website has photos and step-by-step instructions next to each part.
www.aspracing.com/frame.htm
