Cleaning the IAC
Old Jan 24, 2005 | 10:55 AM
Inhot's Avatar
Cleaning the IAC
I want to clean this IAC.
How should I go about it?
Should I immerse the cast metal portion containing the piston assembly in a container of carb cleaner and then scrub the piston assembly with a small brush?
I assume I do not want the cylinder assembly (housing the electrical connector) to get wet.
Old Jan 24, 2005 | 01:10 PM
Inhot's Avatar
Never Mind
Tried a search again and came up with this humourous and very informative post on cleaning EGR, throttle body and IAC.
https://www.f150online.com/forums/li...ebodyclean.php
Old Jan 24, 2005 | 01:17 PM
JMC's Avatar
JMC
25 Year Member
Spray carb or throttle body cleaner into it and let it sit. Empty it and wipe it with a clean rag. Reset the PCM so your truck will relearn its idle strategy.
Regards
Jean Marc Chartier
