Got A Miss
Got A Miss
HI ALL , I HAVE STOCK 2001 F 150 SUPERCREW WITH 53,000 MILES. I BOUGHT IT WHEN IT HAD 19,000 MILES. RUN PERFECT UNTIL 3 MONTHS AGO, BUT I HAVE BEEN IGNORING THE PROBLEM. IT HAS A SLIGHT MISS AND JUMPING AND BUCKING UNDER LOAD. HAS NEVER SET A LIGHT UNTIL LAST WEEK. THEN I LET IT IDLE FOR A WHILE WARMING UP, RAN PERFECT FOR THE AFTERNOON AND LIGHT WENT OUT. THEN THIS SAT THE MISS GOT WORSE UNDER LOAD AND CHECK ENGINE LIGHT CAME ON. WELL I TOOK IT UP THE STREET TO A SHOP THAT WE SOMETIMES USE FOR ALIGNMENTS AND HAD THEM RUN THE CODES AND THIS IS WHAT THEY COME UP WITH, CODE P0306 CYL#6 MISFIRE. I HAD HEARD THE PROBLEMS WITH THE COILPAKS AND BOUGHT ONE JUST IN CASE. I JUST DIDNT KNOW WITH CYL IT WAS. WELL TONIGHT I CHANGED THE #6 COILPAK OUT AND THE WAS NO CHANGE. I HAVEN'T CHANGED THE SPARK PLUGS, BUT I WILL TUESDAY NIGHT TO SEE IF THAT HELPS. THE CODE DID NOT COMEBACK ON YET. ANYONE HAVE ANY OTHER IDEAS?
THANKS LARRY
THANKS LARRY
Originally posted by vettediver69
THANKS I WAS TOLD BY THE SERVICE DEPT IT WAS THE FRONT RIGHT SIDE. SHOULD HAVE KNOWN BETTER.
THANKS LARRY
THANKS LARRY
By the way, using CAPLOCKS is considered shouting.
welcome to f150 online
