'97 F150 5.4 running rough all the sudden, please help...
This is a '97 5.4 with 115,000miles. I have a big loss of power and the engine shudders during acceleration, like its not running on all 8cyl. Truck idles fine, but as soon as you put it in gear it begins to miss, the more throttle the worse it gets. Started all the sudden. No engine light. I'm not sure what to look for on these trucks mainly because i've never had a problem with it. Any ideas greatly appreciated. Thanks in advance.
pat
pat
hey i know this shouldnt go in here but i just wanted to thank EVERYONE for doing a great job with this site...whether you know it or not 1000's of you have helped many of us. Im a college student and know a little bit about working on vehicals but the easiest way to put it is you guys have saved probably more then a $1000 or more on my truck just being able to ask you guys ?'s and serch threw previous posts. most of the replies i get are same day ! which is really great since this is my only vehical. right now i have a high flow intake.... flowmaster 40 series si/Do and superchips max 1715 and yes it shows the trouble codes which does help but with out serching on here and finding tricks or commmon problems it still would have taken time and money to narrow it down to the problem. so i just wanted to thank you guys VERY MUCH for helping me save a huge deal of money and time. It truely is the BEST vehical site. thanks!!!
f150 running rough
My dad's 99 5.4 f150 had the same problem, although it ran rough when idling and under acceleration but would somewhat smooth out when at 1500 to 2500 rpm. We took it to a shop and it turns out ford designed the coolant hose to go over the spark plug wire for the number 4 cylinder, and the coolant hose had a pin hole leak from being worn, and shorted out the coil for the number 4 cylinder, causing it not to fire. So this could be what is wrong with your truck.
Sounds like the coil pack on one of your cylinders. Mine did the same thing last week and I got it fixxed for about $140. But yesturday another one went bad so it's gonna get fixxed again tommarow. What happened to mine was too much offroading. The coil packs got hot and when i hit the water everything in the engine compartment got soaked and the water destroyed the coil packs.
