Cold start problem 4.6
Wondering if anyone else has had this problem. When the temp gets frigid here in ohio, I start the truck and it dies. I have to give it an little gas to keep it going. Its not like i have to hold the pedal for an long time. 99 f-150 4.6.
Only when it gets below @ 20 F on a cold start up. I have to hold my foot on it a little for 30 to 60 seconds. Then it idles fine. After the initial cold start up it is good for hours untill it really cools off. What is it that causes this? I have a 98 4.6 F-150
,Dan
,Dan
same problem here
I have the same problem with my 1997 4.6L If I just start it the RPM goes to about 800-1000 and then it just cuts out. I did this 3-4 times this morning and then I had to put my foot on the gas for about 3-5 seconds and keep the rpm between 1500-1800. After those few seconds it was good and idled for 10 minutes, while I got ready to leave. I did have the check engine light on for a while but then I put in fuel injector cleaner in the gas tank, and its been off since. When I first got my truck back in July it was used with 93,000 miles on it. I was getting about 15.8 mpg. Now I am only getting about 12. Some of this must be due to the cold weather, and extra weight from the sand bags. Even if i don't let it idle long before I drive I was still getting low gas millage. Where are the O2 sensors located? I think I might try changing those. Does anyone have a picture that shows where they are? I am also going to have someone I know take a look at it and get it up on a lift. If anyone finds out anything please post back as I will do the same. Thanks.
I have the same exact problem with my truck here in Maine (97 F-150 4.6 106,000 miles). It has been frigid up here and my truck won't idle on a cold morning. I have to keep on the gas for a few seconds. After that it is fine for the day. I am also looking for help.
Originally posted by mister ed
I had the same problem on amy 2000 Expy 4.6. Went to Auto Zone 54.00 and change, IAC. It took all of 5min to put on. I saved and cleaned the old one for next time.
Did it cure the problem ? How cold was it in MO when yours was doing it ? ,Dan :santa:
It was in the teens with a wind chill of single digets.
It does dip down in single digets in the winter. Biggest problem is wind chill.
Yes it sloved the problem. The cold weather is why I bought one. I hate cold weather and did not want to stay out too long. Hope this helps.
Where is the IAC located at so I can check it as my truck didn't want to start the first time I cranked it yesterday and it has a brand new battery in it as I just replace the old one a couple weeks ago I had to give it some gas to get it going the 2nd time I cranked it to get it going and themp was around 20 at the time.
