Codes P0171/P0174
Old Dec 18, 2004 | 12:09 AM
FordFairlane's Avatar
Post Codes P0171/P0174
P0171-P0174 Lean Condition I know there is tons o info on these but i'll add some findings and when it's fixed maybe it'll help someone else. Removed intake manifold today to inspect PCV and hoses.PCV systems= Good. O2 Sensors=Good. Maf sensor=Good.Vacuume hoses and connections=Good,Vacuum readings, low 50s and steady.Next will be fuel pressure checks and coolant temp sensor.Update tomorrow...James
Old Dec 18, 2004 | 11:58 PM
Yankee1509's Avatar
I get those codes too and did the same thing, everything seemed to check out OK. One thing I did discover though is that the Cat. converters had been chopped out by a previous owner, I'm wondering if that would cause those readings?
Old Dec 19, 2004 | 12:25 AM
I,m thinkin about a possible partial restriction in the cat and am going to look at that also,I've noticed a gradual loss of power in the last couple months.
Old Dec 19, 2004 | 12:36 AM
Yankee1509's Avatar
A guy that helps me with my truck suggested that because my cats were cut out it just might be why I always get those codes, but I haven't had any real noticable horsepower problems, So I'm just guessing thats why mine throws up those codes.
Old Dec 19, 2004 | 02:03 AM
I,m no expert but there seems to be alot of info about this topic in the search feature with some succes in PCV, Maf cleaning and a couple other fixes but alot of posts of people lookin for solutions. I,m thinkin i'll check fuel pressure,cts,cats next.
Keep you posted
