must i replace the oil pump?
Old Dec 14, 2004 | 12:59 AM
peterb7777's Avatar
I have a 1995 F-150, 5.0L V8
Oil pressure guage will, after driving for a while, start to fluctuate then drop to 0psi.
If I shut off the engine, and restart, it will usually come back to full pressure for a while.
I drove it like this for a few days, (engine temperature never got higher), but now it's making a rattling sound.
Question: Is the problem most likely the oil pump, and does this new noise mean I've already wrecked the engine?
Thanks for any help anyone can give.
Old Dec 14, 2004 | 05:59 AM
Gearhead99's Avatar
Since you didn't state the mileage.
I would suggest that you pull the oil pan and have a look see.
If you, or previous owners, weren't loyal with the oil changes you're probably slugged up.
If you have a rattling, well sounds like the damage is already done and the bottom end is going away.
Good luck...
